Is it possible to enlongate legs?
xeon.huangxeon.huang Posts: 0
Just wondering. I don't mean scale the leg, but just make it longer (width stays the same). I wanna try long legs like this: http://gamingmemoirs.co.uk/wp-content/uploads/2012/11/bayonetta.jpg
If it's possible, how do I do it?
Tks!
  • BlackFeather1973BlackFeather1973 Posts: 739
    With "Show Hidden Properties" checked in the parameters tab, you get separate dials for scale x, y and z.
    That way you can scale only the height of the legs.
    352 x 748 - 81K
  • xeon.huangxeon.huang Posts: 0
    edited May 2013
    Thanks a lot BlackFeather! Now it works great! :)
    3 more quick questions:
    1) After I've applied a preset pose from the library onto my figure, how do I reset to the original default standing pose?
    2) After I've applied animation to the figure, how do I delete that animation away? Can't seem to find how to delete it.
    3) It seems after I've enlongate the legs and then I add a pose on the figure, the enlongation seems to reset to default and I gotta edit the legs' length again. Any way to fix this?
    Thanks a lot! :)
    Post edited by xeon.huang on
    1. Edit -> Figure -> Zero -> Zero Figure Pose
    Or click the little figure icon in your viewport (it's next to the universal gizmo). It has "Zero Figure Pose" in it's quickmenu.
    2. I don't do much animation, but i suspect deleting the keyframes will work.
    3. Some poses will, some won't. Depends on how they were originally saved. Hold control when loading the pose. It'll give you a menu where you can check off the scaling.
    Ok! That's all for now. Thanks for clearing my doubts! :)
