Drawing on Skin map - Noise appars in Iray rendering
in New Users
Hello everyone, I'm facing a problem when I'm rendering skin with custom drawing on it.
As a newbee in Daz, I draw my lines directly on the jpg skin ( M4Std_limbs.jpg ) , then apply to my Michael 4 Model ( diffuse color). The rendering in 3delight is almost correct, but in iray some noise appears around the lines during the render.
Could someone can guide me or tell me what i'm doing wrong ?
Best regards
1246 x 486 - 685K
Hello,
this issue can be caused by a low texture compression setting in the Iray render settings. The default setting is quite low, 512 or so.
Check the "Advanced" tab of your "Render Settings" and just increase the values to something like this:
Kind regards, Eagle99
Hello, thanks for the prompt reply, I'll check this parameter this evening and port the feedback.
it worked like a charm ! really appreciate your support, thanks
I might actually try this since i always had mind on low.
