Here's my problem...
leo04
I am using the Genesis Male Genital skin and am having a blending issue.
(See the attachment)
So does anyone have any advise on how to blend this?
I want to blend/match the dark to the light this is the torso.
B.
739 x 365 - 327K
Post edited by leo04 on
Hi!
I need a little more information to help you.
What is the UV of each texture set to?
Were the gens made for the texture they're shown with?
The best answer is probably going to be to use the GIMP (or PhotoShop or PaintShop Pro, there are many options) to clone a bit from the body texture's torso area on to the gens texture.
Are you sure all of the material properties match, and that they are using the same shader (copy surface/paste surface copies settings, but not the shader in use)?
To answer your question I think they are two different ones. I am attaching what I think your asking for.
Hi!
Ok, so you're trying to use male genital textures with a female texture and UV. That's going to require a 2d fix - you're going to have to clone/blur the edges to create a new version in an image editor to match the new texture.
