How do I apply a shader to multiple objects at once?
This may seem very stupid but is there anyway to apply a single shader to multiple objects in a scene in one go? I just want to select all the objects in the scene explorer and for instance right click and say change shader or drag and drop a shader from the browser on multiple selected objects. Any help and suggestions will be appreciated.
Hi Willie :)
it's not something you'd normally to, so there's no simple function to do it,.
Save your file before you make any big changes to the shaders,. then...
Open the Shaders tab,.(bottom right panel) Select all the shaders (apart from the "Default" shader" ) and delete them all.
Go to Edit / Remove unused / Shaders. to clear out the shaders from memory.
Since the only material left is the default shader,. it'll be applied to all objects,.
you can now select the default shade,. adjust it's colours to what you need,. (like a blue modelling clay, or whatever) and render.
hope it helps :)
Thank you 3DAGE - that will help a lot. I render my Ambient Occ passes separate and to apply a white 'Lambert' shader to a zillion objects in the scene every time really wastes a lot of time. Will give this a shot. Cheers!!
3dage
I never would have thought of that approach.
Always wanted to try a clay shader render. I like the look but thought I would have to go through every object.
Thanks
8068
Hi Willie.
If you are multi-selecting objects in the instance list, another suggestion;
-Group them.
-With the group selected, edit the shader.
-Back in the assemble room use->'Apply to children' button. Then Ungroup if needed.
If the scene has a Poser import(V4 etc.);
-Select the main model mesh under its animation group(V4.2 its 'Model').
-Edit the shader(Edit button). In the shader room, drag any shader from the menus, browser or shader tab, to the 'Multiple Shading Domains' sphere at the top right.
Hi tbwoq
Thanks, would never have thought about grouping. Brilliant!
