Measure Distance and Angle script
![BradCarsten](https://secure.gravatar.com/avatar/a901ca2711f142523b9eff99ef3cb228?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fa901ca2711f142523b9eff99ef3cb228_100.png)
Here's a quick script to measure the distance between 2 object (in cm) or the angle between 3 objects (in degrees)
It was requested in the following thread, but I decided to add it to the freebies section as well in case anyone else wants it.
This should be quite useful for working out DOF etc
Drag it into a folder eg "My Library" folder (In Windows it's usually in Documents\DAZ 3D\Studio\My Library ).
This is where you'll then find it in your library:
Once you've added it to your library- how do you use it?
Simply select 2 Nodes(Objects) and run the script and it'll measure the distance between them.
Select 3 nodes to measure the angle.
(if you would like to change the order, just create a group and then add the 3 items to the group in which ever order you'd like them to appear- I don't know if there's an easier way, but that seems to work)
Unfortunately because it's a script and not a plugin, you won't get realtime feedback as you move the objects around.
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/86/797f796ee50f6441758e63a8426e41.jpg)
![](/forums/plugins/FileUpload/images/file.png)
Neat, thanks.
Thanks, great little thing, very practical !!
