mcjA3Wedges - Wedge shoes / sandals props for Aiko3
mCasualmCasual Posts: 4,607
edited June 2013 in Freebies
over here ---> https://sites.google.com/site/mcasualsdazscripts3/mcja3wedges
they are shoes for Aiko2's default body
no morphs except a few bend/twist adjustments
here are the making-of images
1- the reference images - Brisa Material Girl - Sold at The Bay.
http://www.thebay.com/eng/shoes-musthaves-BRISA-thebay/294440
2 - the sole which ( needs reshaping )
3 - using ''conver hull'' processing i was able to make the toe strap look tightly fit, not loose and soft and glued to the skin
4 - started laying the 4 other straps
5 - idem
485 x 800 - 43K
800 x 800 - 117K
800 x 800 - 123K
824 x 524 - 78K
200 x 800 - 17K
Post edited by mCasual on
«1
  • mCasualmCasual Posts: 4,607
    more reference and the-making-of images
    890 x 780 - 85K
  • TheCastellanTheCastellan Posts: 709
    always good to see more stuff coming. :D
    some progress ( and some damage )
    1280 x 720 - 109K
    edited June 2013
    just a the-making-of-sneak-peek
    a script with the help of the mcjCollider plugin pushed the straps against the foot
    another script will force the straps to have a very precise and constant width
    i'll also use the occasion to make the straps wider
    and another existing script will build the inflated version of the straps
    400 x 394 - 721K
  • shanteshante Posts: 206
    nice look forward to seeing these done, if smart props might even be able to repurpose them for the V4 girls....maybe?
    edited June 2013
    unfortunately i dont have experience in smart-props
    so they'll probably be very simple props, with a pose file to position Aiko3 in them
    similar to 2 other pair of shoes on my site
    https://sites.google.com/site/mcasualsdazscripts2/mcjaiko3sandals
    i may add a morph or 2 if bending the foot joints causes poke-through
    but i don't want to add the full complement of morphs or make new versions
    because ... i want to get back to finishing the Aiko crop-top and bikini bottom
    those two will be fit'able to Genesis i think
    some progress in the shoe making department
    the strap widths were corrected, also the straps are ''squarier'' unfortunately, just a bit too much what's the word ... sharp
    1280 x 720 - 193K
    with the little i know i have created smart props by simply parenting a prop like a shoe prop to the body part it needs to fit to position re-size whatever until it looks good then save it to the library. haven't done it in a while in P7 but in P4 the dialog box during the saving process asked if you wanted to make it a smart prop and you click yes and voila.
    Next time you want to add the saved prop to a similar body prop in position for either the same figure or similar it Smart Props to the body part it was meant for.
    Though for A3, these cool prop shoes might be able to be repositioned and re-sized to say A4 or V4 and Smart Prop saved to the library for easier re-application later.
    Just an explanation and not something you need do for these...I was just thinking out loud. :(
    shante said:
    . . . in P4 the dialog box during the saving process asked if you wanted to make it a smart prop and you click yes and voila.
    Next time you want to add the saved prop to a similar body prop in position for either the same figure or similar it Smart Props to the body part it was meant for. ...
    thanks! now i know where to look. I have poser 7,
    it could be useful because sometimes people have trouble installing the shoes even with the pose-file and instructions
    latest state of the wedges ( gold plated ! ) the straps are pretty good,
    i still have to improve the innersole and find a good-looking way of tying the straps under the innersoles and at the heels
    1920 x 1080 - 293K
  • Alisa Uh-LisaAlisa Uh-Lisa Posts: 1,308
    Wow - these are looking great!
    edited June 2013
    thanks !
    hoping to have them out this weekend
    Tucking the strap ends under the innersoles ... needs adjustments.
    1280 x 960 - 222K
    edited June 2013
    two more wedge shoes the-making-of pictures
    tomorrow i'll correct the UV maps for really well behaved textures
    and probably add a few morphs ( just the essential )
    note that this is subDivided in daz studio 3 and rendered with Blender/Cycles (exported using mcjTeleblender )
    1280 x 960 - 200K
    1280 x 960 - 221K
    spot-check of the heel assembly and UV
    the UVs do need treatment
    subD / 2Delight software-cartoony render
    512 x 384 - 623K
    edited June 2013
    the UVs ...took hours !
    there's 1 material per strap, the inner-sole, wedge and sole have 3 materials: top / bottom / sides, the heel piece has 2
    for those who want to create lining, add stitching , add studs etc etc and of course prints
    tomorrow i add the 1 oe 2 morphs and i publish them !
    960 x 600 - 155K
    Coolies.
    Looking great!!!
    edited June 2013
    Looking great!!!
    here's with prints
    512 x 384 - 333K
    512 x 384 - 437K
    1600 x 1200 - 302K
    2 minute long video about the wedges, the bodycon and Amy
    https://www.youtube.com/watch?v=OwTr7BT2Tt0
    it delays the delivery of the shoes but ... it makes me happy that i have 1 more video done in 2013
    will the wedges be ready this evening ? this is what we'll see :)
    640 x 320 - 51K
    well since i want to write and use a script to create the foot-bend morphs, the shoes will probably not be released today
    ( though if someone really really wants the static shoes that were used in the youtube video i could upload them )
    Cool :) We can wait :)
    Casual said:
    before i get back to the bikini bottom and crop top for Aiko3
    probably non-morphing / non-bending props
    i'll complete the 'wedges" i started building
    ( i wanted to improve on the scripts i wrote to tightly fit the bodycon dress and apply it to straps )
    5 - idem
    these look nice. i like the style in the middle a lot too. a simple strap for the toes and possibly a strap over the top of the foot to hold it on leaving more of the feet exposed and still a slip-on.
    i doubt wearing a wedge sandal like this will allow the foot to bend much anyway...would it?
    thanks!
    the bend morph is shown below
    from past experience constructing walk animations, some allowance for bending can make life easier
    there will also be "twist morphs"
    each one of the 5 straps has its own surface/material, so one could make them invisible and "patch it" with other straps
    since i want to complete ( one could say "be done with" ) these shoes, they wont have the full set of morphs
    and will be usable mostly with the default Aiko3/Aiko3LE body
    512 x 384 - 550K
    thanks!
    Nice product and I can rig my own to work as smart props with other figures like...oh?....The Freak and Havoc or Fallen! LOL
    Are thee for D/S or Poser?
    more foot bend extravaganza ! ( yeah that's hype )
    192 x 384 - 203K
    edited June 2013
    they are poser props, i modeled them over a posed Aiko3-default-body foot,
    imported the obj in DS3,
    added a few bend/twist morphs using D-Forms,
    then exported them as poser-props using "PP2 Exporter" by Duke533
    edited June 2013
    really close to publishing the shoes !
    i inverted the UV coordinates on the roght shoe
    fixed the material names
    what's next ... making sure the materials are correct amd maybe include a material-preset ( poser poses don't have tiling? )
    400 x 1200 - 80K
  • amy_aimeiamy_aimei Posts: 139
    Casual, your scripts and animations are amazing!
    I would like to know how it works in details, it seems that your scripts are time saving tools.
    It took me many hours to make the cloth wrapping effect around the rings of the bikini I posted recently!
    Casual said:
    Cool, these look nice. Now to fit them around the Runtime. Thanks so much!
    Can't wait to see your next stuffs :3
