Silent Export without showing options AND without showing File Dialog
I have been playing around with the publicly available "Export Selected Object" script.
I use this script in order to export an obj that I later load into blender.
I need to do this for about 3 to 4 things and really just want to hit the button in DAZ that will eport it as my !!ToBlender filename without asking me via a filedialog. I know its super lazy to not hit enter and then YES but I figured this has to be possible. What do I need to change in the FileDialog part in order to get my obj with the settings below to just WriteFile without the file dialog?
I have pasted my current script below.
// DAZ Studio version 4.9.4.117 filetype DAZ Script// Define an anonymous function;// serves as our main loop,// limits the scope of variables(function(){ // Get the primary selection to use for the file name var oNode = Scene.getPrimarySelection(); // If something is selected if( oNode ){ // Get the node's skeleton var oSkeleton = oNode.getSkeleton(); // If it has a skeleton if( oSkeleton ) { // That is the node we want for the name oNode = oSkeleton; } } // Get the export manager var oExportMgr = App.getExportMgr(); // Define the class name the for Wavefront Object (*.obj) exporter var sClassName = "DzObjExporter"; // Find the exporter var oExporter = oExportMgr.findExporterByClassName( sClassName ); // If the exporter exists if( oExporter ){ // Create a settings object var oSettings = new DzFileIOSettings(); // Fill the settings object with the default options from the exporter //oExporter.getDefaultOptions( oSettings ); // Define whether or not to show options var bShowOptions = false; // Define whether or not to show options before prompting for a path; // requires 4.9.3.22 or later var bOptionsBeforeFile = (bShowOptions && App.version64 >= 0x0004000900030016); // Get the options for the exporter if( !oExporter.getOptions( oSettings, bShowOptions && bOptionsBeforeFile, "" ) ){ // We're done... return; } // Debug //print( oSettings.toJsonString() ); // Set the desired settings for the exporter //oSettings.setStringValue( "Preset", "Poser (1 unit = 8ft)" ); // Set the scale to write the data oSettings.setFloatValue( "Scale", 243.84 ); // Set the lateral axis to X oSettings.setStringValue( "LatAxis", "X" ); // Set the vertical axis to Y oSettings.setStringValue( "VertAxis", "Y" ); // Set the depth axis to Z oSettings.setStringValue( "DepthAxis", "Z" ); // Do not invert the lateral axis oSettings.setBoolValue( "InvertLat", false ); // Do not invert the vertical axis oSettings.setBoolValue( "InvertVert", false ); // Do not invert the depth axis oSettings.setBoolValue( "InvertDepth", false ); // Do not ignore the geometry of invisible nodes oSettings.setBoolValue( "IgnoreInvisible", false ); // Do not weld seams between parent and child bones on legacy figures - deprecated oSettings.setBoolValue( "WeldSeams", false ); // Do not remove vertices that are floating, connected to nothing - i.e. LOD oSettings.setBoolValue( "RemoveUnusedVerts", false ); // Write vertex textures - UVs oSettings.setBoolValue( "WriteVT", true ); // Do not write vertex normals oSettings.setBoolValue( "WriteVN", false ); // Do not write object statements for each root node - i.e. figures, props oSettings.setBoolValue( "WriteO", false ); // Write facet groups oSettings.setBoolValue( "WriteG", true ); // Write facet groups according to whatever the geometry already has oSettings.setBoolValue( "GroupGeom", true ); // Do not write facet groups according to the node it is associated with oSettings.setBoolValue( "GroupNodes", false ); // Do not write facet groups according to surface groups oSettings.setBoolValue( "GroupSurfaces", false ); // Do not write one facet group oSettings.setBoolValue( "GroupSingle", false ); // Write surface groups oSettings.setBoolValue( "WriteUsemtl", true ); // Do not write a material library oSettings.setBoolValue( "WriteMtllib", false ); // Do not collect texture maps oSettings.setBoolValue( "CollectMaps", false ); // Do not convert texture maps oSettings.setBoolValue( "ConvertMaps", false ); // If the version is 4.5.0.114 or newer if( App.version64 >= 0x0004000500000072 ){ // Do not limit export to selection oSettings.setBoolValue( "SelectedOnly", true ); // Do not limit export to the selected roots oSettings.setBoolValue( "SelectedRootsOnly", true ); // Do not limit export to the primary selected root; // this setting overrides SelectedRootsOnly oSettings.setBoolValue( "PrimaryRootOnly", false ); // Do not export items that are parented to the selection oSettings.setBoolValue( "IncludeParented", false ); // Do not triangulate n-gons oSettings.setBoolValue( "TriangulateNgons", false ); } // If the version is 4.9.3.22 or newer if( App.version64 >= 0x0004000900030016 ){ // Do not collapse UVs Tiles oSettings.setBoolValue( "CollapseUVTiles", false ); // Show individual settings in the dialog oSettings.setBoolValue( "ShowIndividualSettings", false ); } // Define whether or not to show the options after prompting for a file oSettings.setIntValue( "RunSilent", (bShowOptions && !bOptionsBeforeFile ? 0 : 1) ); // Debug //print( oSettings.toJsonString() ); // If we've got a node, construct the path using the // exporter's last path, the node's name, and the // exporter's extension... // Otherwise, just use the exporter's last path var sInitialPath = ( oNode ? String( "%1/%2.%3" ) .arg( oExportMgr.getExportPath() ) .arg( oNode.name ) .arg( oExporter.getExtension() ) : oExportMgr.getExportPath() ); // Prompt the user to choose a file, // use the exporter to build the title bar caption, // the initial path and the filter var sPath = FileDialog.doFileDialog( false, String( "Custom Export : %1 : %2" ) .arg( oExporter.getDescription() ) .arg( oSettings.getStringValue( "Preset" ) ), "M:/M_Daz/Blender/!!toBlender", String( "%1 (*.%2)" ) .arg( oExporter.getDescription() ) .arg( oExporter.getExtension() ) ); // If the user didn't cancel and the file doesn't already // exist, or the user wants to overwrite it if( sPath && MainWindow.checkExistingFile( sPath ) ){ // Write the file using the options specified oExporter.writeFile( sPath, oSettings ); } // Clean up; don't leak memory oExporter.deleteLater(); // We didn't find an exporter with the class name we wanted } else { // Inform the user MessageBox.critical( qsTr("An exporter with the class name \"%1\" " + "could not be found.").arg( sClassName ), qsTr("Critical Error"), qsTr("&OK") ); } // Finalize the function and invoke})();
Thanks so much
Comment out the whole file dialogue section and then in the immeditely preceeding section change
to
though if you are going to export multiple items you will need to add an index to that.
The master answers again! I appreciate the quick reply however I am not quite able to get this to work. When I comment out the file dialog it seems to be part of an entire statement. It all ends on the line with a ; at the end.
Exactly which line do I comment out? Can you show me a bit more of the edited script so I know what to do. I tried a couple things with your instructions and keep getting compile errors.
Thanks
Sorry, I misread the script - you need to set sPath (using the code to set sInitialPath above, or just hard-coding your desired path of course) to the fiel you want to save.
No worries at all. I understand what you meant now. I have adjusted the script above and it works.
Thanks again so much. You are so very helpful.
Not sure why my code snippet is not formatting but there it is either way.
You're welcome.
The code displays oddly after you post, the page doesn't seem to load in quite the same way - other things, such as post count, also behave oddly until the page is refreshed. The code looks OK now.
