THE fifth DOMENTION!
I am curios while building a model was thinking of how I could make the correct Shader domains with such low polies!
Can you use an IMAGE/TEXTURE map to assign a shader domain?
Say you have a 6 sided cube but want say an CROSS/X on one face or more to have a certain DOMAIN! say you want to assign the CROSS a metals shader
  • Sfariah DSfariah D Posts: 26,503
    What is a domention? I heard of a dimension though
  • AscaniaAscania Posts: 1,855
    Layers/Multichannel with the images in the masking channel.
  • PhilWPhilW Posts: 5,148
    What Ascania said! Make sure you UV map the models to control what part of your maps control the placement on the model.
