How do Hard edges work? (crease angle in poser terms)
in poser used to define hard edge groups with the grouping tool.
it was a bit of work to setup a diamond ring in poser.
how would you set up crease angle and rigid groups in Carrara?
set up a mix of hard and soft edges on a model?
TY
in the vertex room it should just apply smoothing or hard edges to the bits selected, I recall doing both on different parts of a mesh.
modelling room. doh Thanks
trying to figure out how rara interprets hard edges on the DS geometry
in the DS3 days, the smoothing was part of the shader settings. dunno where it is these days
HI Misty :)
Sub division smoothing has a new side panel option, when you select a genesis-ish type of figure (which is setup for sub-d smoothing).
for previous models (Victoria 4/M4 etc) you need to select the model, jump into the vertex modeler, select a poly, and enable "smooth" in the subdivision panel,.
when you return to the assembly room,. you should have the new Smoothing slider options for that figure.
When carrara "Load's" any model,. it re-creates the geometry,. from the file vertex data.
in carrara you can select and crease edges in the vertex modeler,. normally edges are smooth,.
there are a couple of examples of using creased edges and subdivision smoothing in the WGDJohn modeling thread ...(soft drinks can model)
Hope it helps :)
Thank you
ready for another go at this, in the mornin
In the vertex room select the edges or mesh you want to be creased, then Model->Crease Edges (or Model->Smooth Edges). You can specify all edges or a creasing angle in the dialog. Creased edges show as blue in the vertex room. (they will stay as creased if you export that mesh back to Studio).
There's no equivalent to setting a creasing angle in the shaders though, so any models you import from DS will need to be hand-creased.
when i want sharp edges i send the object as an object file to hexagon and save it as a carrara file and open it in carrara nothing more, and no added geometry
does that still work, heard somethin up with hexagon to .car
think i have the old hexagon installer
ty
Thanks
Refer this thread :- https://www.daz3d.com/forums/discussion/231316/hexagon-update-has-broken-export-to-carrara-reportedly
If you have Hexagon 2 the Carrara export still works, but does not in the updated versions.
mistara didnt specify and assumed it was the previous version of hex. sorry what i meant was send the carrara file as a .obj file to hex then reimport it to carrara or save as a carrara file in hex and open it in carrara if you are using hex 2.5.179 and not the beta
Carrara allows you to select and then "Crease" any edges you want.
there's no need to export to another program,. and in doing that,. "which edges are being creased" ..is it All edges,.? surely not.
Creasing selected edges of a model , allows you to model with subdivision smoothing enabled. (while maintaining that creased edge)
it's not common practice to have the entire model with all Creased edges.
this would make it "visually" unaffected by any subdivisions smoothing settings in your 3D program.
If Hexagon is creasing all edges of an imported OBJ file,. when it's saved as a Carrara file,. then that's not right.
