Will This Laptop Configuration Run Daz 4.10?
I'm considering installing Daz Studio on a second device, a two year old Acer laptop, to comlement my relatively high end desktop for rendering "on-the-go". Will this configuration give acceptable performance? I know it won't be able to render complex scenes, but what about just two characters with something like "DAZ Studio Iray HDR Outdoor Environments".
Can it render in IRAY?
  • 6th Generation Intel Core i5-6200U Processor (Up to 2.8GHz)
  • NVIDIA 940MX (Memory Interface DDR3, GDDR5, NVIDIA GPU Boost 2.0, CUDA)
  • 8GB DDR4
  • 256GB SSD
  • Windows 10
1599 x 656 - 115K
  • Memory looks tight, especially if the GPU is taking some of it. If the GPU has its own memory, how much?
  • maikdeckermaikdecker Posts: 2,990
    In a shop it says in the details "NVIDIA GeForce 940MX with 2GB of dedicated DDR5 VRAM"
  • Richard, it looks like it has 2GB of its own, unless I'm not looking at the correct value. See attached screen capture.
    959 x 708 - 79K
  • 2GB isn't much - you might be able to do single-character renders, or some environments, but mostly your renders would drop to CPU. Resizing textures might help a bit (I used to be able to render a single nude character in 1GB, mostly - some with a lot of maps failed even without any other items loaded even then).
  • Ugh, ok. Thank you. I do own that Scene Optimizer product and use it often to resize complex scenes. Thanks for the advice.
  • And thank you, Maikdecker.
