Poser 8 and DSON
edited December 1969 in Poser Discussion
I was looking at the VICTORIA 5 figure and noted you can only install it i poser using the DSON installer. I looked at he DSON installer and it sez it works with Poser 9. Is there any way to get the Victoria 5 files into Power 8 (correctly). I'm familiar with folder structure in poser, and working with .obj files. Is there a manual install process anywhere to put Vic5 into Poser 8?
  • thd777thd777 Posts: 943
    No, you will not be able to use the Genesis based figures at all in Poser 8. It is not a matter of installation. The figures use weight mapping which was only introduced in Poser 9 and also require the add-on framework that was introduced in the SR3.1 for Posser 9.
    TD
  • edited December 1969
    Thanks. That's exactly the kind of efficient, to the point answer I find valuable!
