Is there Angel for G8
Hey guys, I was searching for Angel v4 for Genesis8,, unfortunately, I couldn't find it.
Do you guys know or have her for G8 ???
960 x 1248 - 236K
Post edited by Chohole on
Thank you but I already own her, but I literally wanted angel herself for g8
Angel is for V4, which is a completely separate figure, not a genesis figure. The Angel character for V4 was released 8 years ago.
You could try to transfer her to G8F, but for that, you'd have to jump through quite a few hoops. First of all, the skin UV starting from G3 is no longer compatible with earlier versions. Second, you'd have to get the morphs transferred. Also, if you want to render in Iray, you'd have to change her skin from 3Delight to Iray settings.
Honestly, you would probably be better off using Anagennesis (use the Genesis script) or some other Iray skin converter for V4 (v3digitimes has a good one). and then just using her as is. Its a lot easier than jumping through the hoops required to get her up to G8F (I am in the process of converting all of my V4 to G8F and its a TON of work for each character and involves a fair investment in other products to get them there)
Hey thank you for the advise , But I just forgot about angel v4 and tryied to do angelina jolie the recente virsion , What do you think should I change somenthig ...?
What do you guys think, does she looks like 27 years old Angelina Jolie ?
