RuntimeError: Bad magic number in .pyc file in talk designer
I get a RuntimeError: Bad magic number in .pyc file in talk designer http://www.daz3d.com/shop/talk-designer-assistant-for-poser-8/ , which i just got from the shop today and it does not work... or do i need to use an older version of poser ?
1366 x 768 - 698K
Post edited by zanainternational_0b487b6a6a on
Unfortunately the latest version of Poser uses an updated Python engine, and as a result compiled Python scripts (.pyc) aren't running, with the Magic Number error. With luck all that's needed is a recompile from the original script, though I believe some scripts need more work than that; in any event if you've only just purchased and downloaded that obviously isn't yet done. I would suggest opening a support ticket, asking if there's a status update, and if need be asking for a refund.
Thank you very much for the message, how would I recompile the scripts to fix the error ? Yes i purchased it two days ago and downloaded it, how would i open a support ticket ?
Recompiling needs the original code, so it has to be done by the author.
To open a ticket, click on Contact Us under help at the top of this page.
O.k Thank you, since |I have DAZ studio as well, can talking be done as well ?
Yes, though you need to have the 32 bit version of DS installed (the LipSync plugin doesn't work in 64 bit, fortunately you can have both 32 and 64 bit versions installed on the same machine). LipSync works from a recoding, as I recall, while Talk Designer works from a transcript - but I'm not certain of that.
Thank you very much, i have not heard any response from the creator of talk designer http://www.daz3d.com/shop/talk-designer-assistant-for-poser-8/ why dont you have it built in DAZ ? since the whole idea is to animate , and talking is very much part of humanoid entities.
Ok Will have the same problem with the origonal "talk designer' I use Poser 10 Will "Talk designer assistan 2" have the same issue? I use M4's and V4's, but I want to know if it will work before spending $50
Edited to fix quote
Edited to fix quote
I don't know - I can't recall if verion 9 to version 10 caused this issue or if it was an older update only.
