Carrara 7 keeps...
SkyGSkyG Posts: 0
forgetting the password, so I have to rewrite it every time I open the program. Anything I can do to fix it ? It´s a bit annoying.
Skygirl :)
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,476
    right click exe/shortcut icon, select run as administrator
    then try it
    (it is a predominately Windows Vista issue on a few programs)
  • SkyGSkyG Posts: 0
    Thank you very, very much. It fixed the problem. I run win 8 so it seems not only to be a vista problem. Any way it´s fixed and I´m happy. Thank you so much again !
    Skygirl :)
  • ManStanManStan Posts: 0
    edited June 2013
    Yes, Bill decided you were windows worst enemy so is trying to protect windows from you. By you I mean everyone that uses windows lol
    There is a way to disable this so you don't have to set each app to run as admin. But it have been so long since I did it I've forgotten how :red:
    DAZ, your emotes are broke.
    Post edited by ManStan on
  • 3DAGE3DAGE Posts: 3,311
    You need to be the Administrator,. or have the same privileges as Admin,. in the User Account settings, in order to be allowed to install and register applications onto a system.
    Check your user account settings,. or log in as administrator , or right click as Wendy suggests and select (Run as administrator)
    then the system will allow the serial number to register for that application.
  • SkyGSkyG Posts: 0
    Thanks to you too. I worked out well and the password stays where it should, so I´m happy again.
    Skygirl :)
