visible in render / visible in viewport
BradCarstenBradCarsten Posts: 856
edited February 2018 in New Users
I have a cube,
Under properties, if I set "visible in render" to false and 'visible' to true, then predictably the item is visible in the viewport, but it doesn't render.
But if I set "visible in render" to true and 'visible' to false, the item is invisible in the viewport, but for some reason it doesn't render.either.
Why is that?
Im using DazStudio 4.10. 3delight render. I'm not on my main pc so I haven't tried this in iray.
Post edited by BradCarsten on
  • Currently you can't make things invisible in Viewport but visible in render, however
    • Added a “Visible in Viewport” property to all nodes (DzNode); when enabled (default), the geometry/avatar for a given node is drawn in the viewport; when disabled, the geometry/avatar for a given node is not drawn; when disabled and the node is selected, the bounding box for the node is drawn (draw style settings permitting)
    • Reordered node properties to better suggest that the “Visible” property is a superset of “Visible in *” properties
    • Added support for the “Visible in Viewport” property to group nodes, camera nodes, light nodes and instance nodes
    In DAZ Studio : Incremented build number to 4.11.0.36 http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#private_channel
  • Oh that's a pity.
    Thanks for the additional info.
