Non-locality
Design AcrobatDesign Acrobat Posts: 459
Can a polygonal model be made so small that it cannot be located with a 3d camera in Carrara?
    try selecting the object in the instances tab and hitting 0 which should make the camera point to it
    or try scaling it to a specific size.
    Are you in a "large" scene? then yes it's easy to lose things at that scale....
    if the object was imported make sure it's scale numbers are not negative... I've seen this and have no idea what causes it...
  • Design AcrobatDesign Acrobat Posts: 459
    hmmm, minus numbers....
  • edited December 1969
    YESSS AMOUNT NEGATIVE "X" Very interesting!
  • 3DAGE3DAGE Posts: 3,311
    Hi Design Acrobat :)
    What format is the model,.
    what program is it from,.
    what import options are you selecting ?
    is it something you can share ? or post a screen capture,. so we could have a look.
    No idea what causes this.... I never found a way to fix it.
    Be sure to post if you find a solution.
    Pretty sure it was OBJ format import.
    Gotta find the file again as it's on another computer's hard drive, D,E, F, H, I or J.
    Just gotta narrow it down or maybe It was on the backup drive Alpha 1 or Alpha 2.
    It was one of those post midnight adventures right before the sun came up.
    It's all blurry but there was a pickle and peanut butter sandwich involved.
    Things were so much easier when everything was stored on a single floppy disk.
    the program and your work files.
