Converting quads to triangles
![Daywalker Designs](https://delorean.daz3d.com/forums/uploads/userpics/241/nHUIZ8P7NQMQV.jpg)
I'm starting to work on a plug-in project that will add AMD's open source version of ProRender as a render engine and was wondering what the most efficient way to convert quads was since the current implementation I'm working with only has native support for triangles. Any suggestions?
Hi!
I found this trick which I used in script test, which probably can work on DzFacets too (I haven't tested).
The idea is, read the Facets, if they are quads
turn them into tris using
tri 1: oFacet.vertId1, oFacet.vertId2, oFacet.vertId3
tri 2: oFacet.vertId1, oFacet.vertId3, oFacet.vertId4
I tried it processing an exported OBJ but will "soon" try it directly on a DzFacet.
