Cheirocrates les romantiques Texture missing
Martial
Bonjour
I just inatall this new product and poser ask me about
I do an intensive search with Ultrafilesearch exe on all my drives and find nowhere this jpg
Is it missing?
Suggestio please ?
Thanks
Hello!
I cannot use this product at all, all I get is error messages. I have Cheirocrates selected when I try to apply the Less Romantiques mat pose and all I get is these error messages:
Some assets needed to load the files were missing. The content may not work as expected. The following files could not be found.
/data/Jack Tomalin/Cheir/CHE_Light/che_light_3972.dsf
/data/Jack Tomalin/Cheir/CHE_Gr_Sd_Walk_1/che_gr_sd_walk_1_532.dsf
/data/Jack Tomalin/Cheir/CHE_Planter/che_planter_1740.dsf
/data/Jack Tomalin/Cheir/CHE_Fence/che_fence_6380.dsf
/data/Jack Tomalin/Cheir/CHE_Gr_Rd/che_gr_rd_9.dsf
/data/Jack Tomalin/Cheir/CHE_Tower/che_tower_67960.dsf
/data/Jack Tomalin/Cheir/CHE_Bench/che_bench_3740.dsf
Then it loads an empty block into my picture and the materials does not become applied to the Cheirocrates set.
Sounds as if you are opening a scene file, not the materials preset.
Using Windows Explorer, I copied fence_pst.jpg and renamed the copy fence_pstAddon.jpg. fence_pst.jpg doesn't actually seem to be used in either of the two Poser preload cr2s.
While there may very well be differences between the base textures and the Addon textures, I couldn't see any.
Also, one of the lights (che_light_3) in preload !LR_Pre_Sec_1 does not load with the correct settings.
And ... another also. I just tried loading the Bridge of Cheirocrates BRCH_Bank and the three water textures (brch_st_water.jpg, brch_st_water_B.jpg, brch_st_water_T.jpg) are missing from the Bridge_of_Cher folder.
Thanks for the suggestion
For now i just change the name for fence_pst.jpg for fence_pstAddon.jpg and load the file
But i hope the vendor see this post and add the missing file to his product
