Some shortcuts gone?
Ravioli777
I used to use ctrl-z quite a bit to undo and also ctrl-d to drop an object to the floor. Today the shortcuts don't work, and aren't listed in the drop down menus. This happen to anyone else?
Just checked and both work for me along with showing them as shortcuts on the menu.
I'm using ds 4.5 if that makes a difference...
Window>Workspace>Select Layout and choose the layout you are using to reset the custom actions, or go to the AppData folder (Windows) for DS - C:\Users\You\AppData\Roaming\DAZ 3D\Studio 4 on Windows Vista or later, you will need to enable the display of hidden files and folders in Control Panel>Folder Options - and delete actions.dsx to force DS to recreate the default actions and shortcuts.
Resetting the layout did the trick. Thanks!
