HDRI with LuxRender plugin
Hello
Since yesterday I use LuxRender.
Can one tell me how to adjust LuxRender, so that I can render with HDRI files ? So, about HDRI lighting
Where do I need to load the HDRI file. Normal in Carrara, or anywhere else that I need to include?
Sorry for my English.
I'am from Germany
regards
Mark
HI Mark
for Luxus ;
Add a "Lux Infinite" light, then you'll see a box, for the Map,. browse to your HDRI
Set the renderer to Luxus,. and render.
(see pic2)
Normally, in Carrara,. using the "photorealistic" renderer,.
Select the "Scene" in the instance list, (bottom right) then select the "Background", in the (top right) section.
then add your HDRI,.
to enable HDRI, you need to set the rendering option to (skylight)
(See pic1)
hope it helps :)
Thanks!
Great Tipp
