3D Bridge, Photoshop CS6 Extended, Photoshop CC
buck415buck415 Posts: 57
Versions:
DS 4.6.0.18
3D Bridge v1.3.018 (downloaded and installed 2013-06-13)
Problem:
When attempting to activate 3D Bridge in PS CS6 Extended, get error message:
Adobe Photoshop CS6 Extended
Could not complete the DAZ Studio 3D Bridge command because of a program error.
Description
I downloaded the most current version today, and during the re-installation process deleted the previous version through the automatic installation process.
Concern
The new version of Photoshop ( Photoshop CC ) becomes available on 2013-06-17, and I'm upgrading to it.
Question
Is this just my system, or is there a fix?
Thanks
  • frank0314frank0314 Posts: 13,920
    Where are you installing the bridge to
    Keep in mind also DS, the bridge, and Photoshop all need to be the same bit, either 32 or 64, for it to work properly.
  • buck415buck415 Posts: 57
    It's being installed on the C drive in the default DS4 application, not the content directory.
    Yep, got that. Everything is 64x. Thank you.
  • LindseyLindsey Posts: 1,985
    There was a discussion about this same issue in this thread that may explain your issue. http://www.daz3d.com/forums/discussion/19651/
    Ah, that explains it.
    Well, Photoshop CC is released next Monday, so hopefully it will work with that version.
    Thank you.
