Carrara 8.5.0.149 Beta Now Available To Carrara 8 Customers
CARRARA 8.5.0.149 is the latest Beta Build!
We are making this build available for $0.00 as a store item CARRARA 8.5.0.149 Beta You can run the production build of Carrara 8.1 side by side with this Beta build. Just don't uninstall 8.1 version when you install this beta release.
The purpose of providing this build is for you to see the progress we are making, see how Genesis looks in Carrara, see the new features we've added and provide input on the changes. You can also see the list of bug fixes below. This list identifies issues that were logged in the bug tracker and highlights many of the other fixes in this build.
New in Carrara 8.5:
1. Support for imported Genesis .dsf files (best used with DAZ Studio 4.0.3.19 or newer installed).
2. Character presets can be applied. Go to the Instance Tab, select the 2nd Genesis listed in the tree or the Actor line, and double click the character from the list. If the one of these items is not selected, an additional figure will be loaded with that character applied.
3. New Parameters Pane and user experience
4. Carrara 8.5 Parameter Pane. If you are familiar with the Parameters Tab (with the Genesis figure) in DAZ Studio 4, the equivalent to Carrara 8.5 is the Parameter Pane which is accessed by selecting the second Genesis from the list.
5. Shaping in Parameters Pane. If you are familiar with the Shaping Tab in DAZ Studio 4, the equivalent for Carrara 8.5 can be accessed by selecting the Actor line from the tree in the Instance Pane.
6. Content Management System or CMS connection to utilize the DAZ Studio database (requires DAZ Studio 4.0.3.19 or newer recommended to be installed). We are looking into a project to install the CMS for Carrara without the need of DAZ Studio. So for the Carrara customers not using DAZ Studio they can still take advantage of the new system. More information will be coming.
7. AutoFit is included in Carrara 8.5
8. Fit To (auto generates Genesis morphs) for Genesis designed clothing
9. Restore Figure tools
10. Memorize tools
11. Zero Figure tools
12. Smart Content Tab (shows all the content with meta data organized similarly to DAZ Studio's Smart Content Tab)
13. New SubD / Smoothing tool (display the smoothing slider of smoothed vertex object in the assemble room)
14. Improved Bullet Physics for soft body simulation
15. aniBlock importer has been updated and fixed for Carrara 8.5
16. Mac OSX Lion support has been implemented
17. Geo grafting has been implemented and we continue to work on this feature
18. New Light Icons to better represent the lights, the controls have also been improved.
19. DUF Files from DAZ Studio are now supported in Carrara 8.5 however, DUF material presets do not always apply textures to the selected figure.
If you are seeing issues please log the bugs in the bug tracker: DAZ BUG Tracker
Changes since the last beta build include:
Rendering : Fixed #0045322 : Fixed too blurry texture when using Gaussian filtering
Rendering : Implemented : Optimized Gaussian filtering speed
Rendering : Fixed #0045322 : Fixed too blurry texture when using Fast Mip-Map filtering
Rendering : Implemented : Optimized Fast Mip-Map filtering speed
Carrara : Fixed #0046807 : Fixed camera "Set Position To" undo issue
Carrara : Fixed #0046163 : Fixed splat primitive bounding box size
Carrara : Fixed #0046803 : Fixed camera popup list update issue when renaming a camera
Carrara : Fixed #0046824 : Fixed deadlock with projection shader and displacement
Carrara : Fixed #0046825 : Fixed crash when opening the scene attached to this bug report
Carrara : Implemented : Updated French translation
Mac : Implemented : Implemented sleep function
DSF : Fixed #0046510 : Fixed grafting rigidity crash
DSF : Fixed #0043643 : Fixed morphs issue on some content
DSF : Fixed : Fixed crash with conforming when the object does not have any geometry
DSF : Fixed #0044491 : Fixed issue with bulge
DSF : Fixed #0046451 : Fixed corruption issue with autofit and conforming
What you need to know about this build:
1. If you get a Duplicate ID error, please reset your download for the content and try reinstalling. If the issue persists please place it in the Content Project of the bugtracker (http://bugs.daz3d.com) as we believe we have fixed all of those.
2. Pz2 material Presets do work on Genesis and Triax Content, to include content that has been auto-fit to Genesis now.
3. PZ2 Poses do apply to Genesis but it is not recommended and if the pose has translations on the feet or hands those will need to be zeroed.
4. DAZ Studio4.0.3.47 minimum, (4.5 RC2 recommended) must be installed prior to running Carrara 8.5 in order to use Genesis or the Smart Content Tab.
5. If new content with meta data is installed, DAZ Studio will need to be started in order to get the smart content into the CMS database.
6. V4/M4/K4 shaders will not work on Genesis and will have to be manually built.
7. Our development team is working on the tools to transfer data from DAZ Studio 4 to Carrara using our new file format.
8. Included Tree presets may not look the same as they did in Carrara 7, we are looking into this currently.
9. Adding IK to genesis works correctly and as expected, Genesis doesn't load with IK. (In either DS or Carrara)
10. Mimic fixes have been implemented for Gen 4 and earlier.
11. Mimic and Mimic Pro for Genesis is fixed and will be made available to those who have purchases this.
12. Plugins for the previous builds of 8.0 are expected to work with this version.
13. The CMS service is not embedded in this installer. You will need to have installed DS 4.0.3+ “with Content” to be able to use that functionality.
How do I get this updated Beta Build of Carrara 8.5?
To register the Carrara 8.5 Beta you will need to use the serial code listed here: CDZCPRO-085-0000021-XZX-001-EBTOLKY (Expires July 14th 2012)
About Mimic Pro and this build:
If you own Mimic Pro and want to start using it with Genesis, you'll need to download a build just for Carrara 8.5.0.149. You will NOT want to use this with your 8.1 build of Carrara. It won't work with both builds. However, if you install the new version in a different location, you can continue to have both versions on your machine. The same serial number will continue to work for both builds. The DMC files are also included in this new version of Mimic Pro and will work with Genesis.
To see many of the new features and read the latest news on Carrara 8.5 visit CarraraCafe
FOLLOW THIS DISCUSSION AND COMMUNITY COMMENTS IN THE CARRARA DISCUSSION FORUM THREAD
