Bryce 5
lauradawn
Hi, i used to use bryce 5 and have my serial number, but i cant seem to find the download, has it gone for good?
Thanks
Thanks
Did you buy it from Daz ? If so the download should still be in your product library https://www.daz3d.com/downloader/customer/files
Hi Chohole, yes i did, but when i go to install it from my product library it wont install, its says theres something missing and ends up in the ready to install bit of Install manager,
i also get it with "Photoshop 3D Bridge for DAZ Studio 4.10+ and says
Install Manager cannot find a required path. The package for "Photoshop 3D Bridge for DAZ Studio 4.10+ (Win 64-bit)" requires that the installed path for "Photoshop CC, CS6, CS5, CS4 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
I dont really know if these two are related in any way?
Thanks for answering :)
Don't use DIM, it's for Daz Studio only and doesn't work properly for Bryce or Carrara. Download the ZIP file, unpack in a temporary folder of your choice, then install manually from there. See this PDF: https://horo.ch/docs/mine/pdf/BryceContent_v4.pdf
oh brill, thank you Horo
Yes, sorry I should have mentioned that. My Bryce 5 came on a CD from Corel.
thats ok Chohole, all sorted now thanks for your help :)
