Subdivision?
I tried looking this up used two different search engines and searched the forums. So if it exists I have no clue where. The terrain I have is a bit stretched due to low poly's which leads to some odd geometry, however, I know from experience that subdividing helps when it comes to such a thing usually. Though subdividing before editing would probably work better.
  • HoroHoro Posts: 10,537
    Malus - Bryce has a terrain editor (TE) and works with height maps, not geometry - though you can export a height map as geometry. A height map is a grey scale image where higher is brighter. In the TE several file types can be imported. Good choices are TIF and PNG 16 bit unsigned integer monochrome.
  • MalusMalus Posts: 370
    I already know that. Still looking at the wireframe it makes it out to be a bit odd maybe I should change the format and see if that does work. I exported it as a PNG that is my usual format.
