She's not as pretty as I thought she'd be....
NedKelly
You know, I really thought that Victoria 6 would have been prettier than this.
574 x 699 - 47K
Goto My Account / Product Library, type in "genesis 2" into filter, download then install. Or if you use DIM it should in the stack to download and install.
Yeah, I've tried installing it with the DIM and manually but after three attempts with both methods this is still the result. There are files missing according to DAZ4.6.
You need to install "Genesis 2 Female Starter Essentials".
I have installed “Genesis 2 Female Starter Essentials”. I have installed it and uninstalled it and reinstalled it but it is missing some files. I am currently searching my drives to see if the files maybe installed to an unmapped directory but failing that then I have no idea what is going wrong.
They are in the manually downloaded DIM folder. You can get that, unzip it and slide the files you need into place.
Ok, I got it working by running the DB Maintainance program so not really sure what the issue was but it's all good now.
