Controlling multiple nodes in DS4.X?
In Daz Studio 3, if you selected multiple nodes in the scene tab, you could manipulate them all at the same time. In Daz Studio 4, this doesn't seem to work. Only 1 node will move regardless of how many are selected. Does anyone know how to change this so that multiple nodes can be selected and used together?
  • SixDsSixDs Posts: 2,384
    I'm not at the computer with DAZ Studio 4.10 installed at the moment, so I cannot confirm with that (although I would expect that it also works there), but this computer has DAZ Studio 4.6 installed and selecting multiple nodes works as expected. However, if you select multiple nodes in the Scene tab, that will make them show under the Parameters tab but they must also both be selected there in order to manipulate them in tandem, otherwise only the first will move. If, for example, you select both the right and left eyes in the Scene tab and both the right and left eyes in the Parameters tab, then both should move in unison.
  • Richard HaseltineRichard Haseltine Posts: 102,837
    In the Parameters pane option menu (lined button in the top corner, or right-click the tab) make sure that Consolidate Properties is checked and that Display Separate Items is not checked.
