Where is the Default Iray HDRI image?
tombraider4ever
in New Users
I really like using the Default Iray HDRI when I'm posing and setting up my characters and scenes, but I usually user other lighting when I render. The problem is when I load a saved scene, a scene that has been saved using a different HDRI, how do I find the Default HDRI again? I have choosen browse and tried to find it but I can't so my question is where is it?
Please, I would love to be able to load the Default HDRI when I want.
Well if you click on the render settings tab and "default" it should bring it back, but that will change any other settings you have made. I'm just going to switch on my rendering PC so I'll take a look and see where mine is (if noone replies before I've got that far).
39 minutes on a world wide forum isn't long :)
As far as I can remember it is in the Studio Program folder under Resources.
I'm not sure if resetting the Environment Map to default would also work.
Yes, mine is here: Program Files/DAZ 3D/DAZStudio4/shaders/iray/resources/DTHDR-RunsB-500.hdr
Sorry for beeing impatient earlier, Thank you so much for the replies, I found it!
Thank you.
