Help me remove this thing!
TheOwlTheOwl Posts: 29
I am trying to make a fantasy map from bryce and as you can see there is a problem.
I tried pushing the land mass down below the water floor but the "square edges" still shows.
Help!
1754 x 875 - 178K
  • OroborosOroboros Posts: 326
    Several ways.
    1) Select water plane > Edit Materials... [M] > Transparency =0
    2) Select Terrain > Edit Terrain [E] > reveal clipping range > move low end up til terrain under water vanishes.
    3) Select water plane > Edit Materials... [M] > Reflection =100; Edit Sky, alter Sky dome and Ambience to a blue color
    4) Select Terrain, scale it up huge and deep so that only the top of the terrain protrudes above the water; convert water plane to a slab and increase density.
    ...And many others.
  • TheOwlTheOwl Posts: 29
    Thank you very much for your assistance. You just saved alot of my hair from being pulled.
  • GussNemoGussNemo Posts: 1,855
    Best to be bald before starting. :-) (smileys still not working)
  • TrishTrish Posts: 2,625
    Guss; you are sooooooo bad......LOL
    To avoid hair being pulled:
    1) Enter bathroom, select razor; shave head.
    2) Select liquid soap or machine oil tool; apply to hands.
    3) Quit Bryce.
    4) Remove hands (may cause adverse changes in lifestyle: consult a qualified medical professional beforehand, so-to-speak, as removing the second hand can be more frustrating than initially thought)
    ...And many others.
  • HoroHoro Posts: 10,638
    Some great advice here
    @Trish: Why, thank you. :-)
