geometry editor daz3d select by surface
I have an outfit that has the same material for the belt and the top and I just want to remove the belt with the geometry editor.
Is there a way I can only select this surface and then remove the top from the selection to delete the belt?
edit: NVM I hid the "body" material of the outfit and then there was only the belt and top and was able to remove it that way.-
Post edited by Illidanstorm on
Another option, depending on how the model was made, might have been to select one polygon on the belt (or on the top) and then press cmd/ctrl * to select all of the connected polygons, then if necessary use the - buttons in tool Settings to exclude any excess selections.
