Character Position (aka Parameters) After Pose
I loaded up a character (Genesis to be exact). It was standing in the center of the floor (all the Translation parameters are set to 0). I applied a pose. Genesis moved forward and to the left but the transform settings are all still set to 0. Since I've got a Head Lamp Blocker also sitting right there at 0,0,0, I know where it is on the floor. So I move Genesis back to be right on top of that spot. Only the translation settings now read xTranslate = 35.64 and zTranslate = -93.51. If I zero Genesis from the pose, it moves right back on top of the Head Lamp Blocker, only the translate params are all back to 0,0,0. What's going on??? How can the same spot on the floor have two different transform settings? And how can the character be positioned at 0,0,0, when it's obviously not there?
The pose you applied obviously moves the hip bone, check the translations values for the hip, you can zero them if needed;)
Aha! That's where it's hiding. Thanks!
No prob;)
