Is the DIM dim or am i?
Hi
I purchased an item this evening and discovered that unless i want to install it manually i appear to have to use the download install manager. Thats no problem because i have had this for a while now and found it to be very good. On opening the DIM however, i was presented with an option to install an update, which i accepted. Since then the thing has simply sat there doing very little except be annoying. The only way i can get rid and get on with life is by force quitting. Anyone know whats going on here please?
1046 x 661 - 547K
Sounds like your DIM may have been corrupted have you tried uninstalling and reinstalling it?
Elli
Thanks, it was just that the update took longer to load than i would have thought possible. All sorted now, thank you for the help
