Pok-away and Carrara
JamyJamy Posts: 192
edited April 2018 in Carrara Discussion
Hi,
I bought Pok-Away (in 2015), but I never used it.
I do not know how to use this thing in Carrara.
Yet, in the description, it says that it works with Carrara, but I do not see anything in the menu marked Pok pok or pok
Do you know how to use this thing in my favorite software?
Thank you
Salut,
j'ai acheté pok, mais je ne l'ai jamais utilisé.
Je ne sais pas comment utiliser ce truc dans Carrara.
Pourtant, dans le descriptif, il est dit que cela fonctionne avec Carrara, mais je ne vois rien dans le menu marqué Pok pok pok
Savez-vous comment utiliser ce truc dans mon logiciel préféré ?
Merci
1062 x 608 - 282K
Post edited by Jamy on
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,371
    poke away not pok
    and its under the parameters
    I find soft select in the vertex room more preciseas it shrinks whole areas so if any parts exposed by clothing they look oddand withered
  • Bunyip02Bunyip02 Posts: 8,734
    edited April 2018
    I use both Poke Away and Wendys method.
    2270 x 1035 - 466K
    Post edited by Bunyip02 on
  • JamyJamy Posts: 192
    Thank you everybody :-)
    in fact, I used it without knowing it.
    But that does not work with all the clothes.
    mebbe this tutt will help smiley
    Merci :-)
