Help for putting objects into Bryce
TrishTrish Posts: 2,625
If you are stuck and afraid to ask because you think its a dumb question don't be everyone here will help you we are a great group of people.......we all help each other so I made a little help file if you care to read it here it is..............
653 x 552 - 120K
578 x 779 - 148K
430 x 585 - 167K
1274 x 1017 - 571K
1747 x 959 - 714K
  • TrishTrish Posts: 2,625
    and on
    1920 x 1080 - 809K
    1478 x 966 - 607K
    1884 x 1005 - 412K
    727 x 491 - 108K
  • HoroHoro Posts: 10,638
    Good idea, thank you!
    Thank You kind Sir I was remembering earlier that I was confused about this when I first started......and sometimes I am still confused about things I should already know by now as you have probably guessed.....LOL
  • mermaid010mermaid010 Posts: 5,486
    edited June 2013
    Thanks, this will be very helpful for newbies like me.
    Edited to add: I don't use Daz and most of my objects are freebies ;)
    Maybe a follow up on how to "dress up" the objects with the images provided with some objects e.g. Link removed by a moderator
    Post edited by Chohole on
    edited June 2013
    Mermaid010; I have downloaded the model you sent the shortcut to........I will work on this later today...Keep in mind that putting her into Bryce she will remain in that pose.......but you should be able to use the textures that comes with her (I hope) or you can make your own.I promise to look into this in the afternoon....Trish
    Post edited by Trish on
    Mermaid....Heres what I found out and I am not by an means trying to get you to use a program you don't want to but there are some problems with models downloaded that I can not fix maybe someone with more knowledge can anyway check out the new pictures
    1112 x 653 - 405K
    769 x 452 - 96K
    949 x 703 - 355K
    Mermaid and Trish, I have sent you a PM.
    Thanks Trish, I only downloaded the model so I could have one for David's new tut and started messing around with her for fun. For David's tut, I needed to use default material.
    I think it's time I installed Daz. I grabbed the free version when it was available.
    Thanks Pam for your pm.
    edited June 2013
    mermaid; ok good do that and I will help as much as I can please keep in mind I am not great at Studio .....It is still a learning process for me as well.......but if I don't know the answer there is always the people at the new users help forum...Trish
    Thanks, Trish I'm sure there will be a lot of help in the Daz forum, as we have here in the Bryce forum :)
