Lighting 3D VS Iray
AlfawulfAlfawulf Posts: 174
Ok guys/gals I want to use some Iray lighting as some of my special effects require it.
Trick is, looking in my smart content how do I tell an Iray light from a 3D one??
Also, are their any "tricks" to getting 3d lights to render in Iray??
Thanx in advance!!
  • Sven DullahSven Dullah Posts: 7,621
    The DS standard lights can be used in both render engines. Select your renderer first, then add lights, that way they will be automagically configured for the current render engine. HDRI lighting can now be used in 3DL thanks to Parris' IBL-Master. Check it out!
    3DL lights that DON'T work in IRay are UE2 (UberEnvironment2), AoA lights, Uber Area light shader, dz shaderlights.
