It's been a while....and I'm braindead
whispers65whispers65 Posts: 952
Ok it's been a while (my 15 year old nephew has cancer and the last 6 months have been rough. He took tests yesterday to see if he is in remission and get ready for radiation....ugh.....good news is that docs recommended him for the Make-A-Wish foundation and they called. :) )
ok so I use DIM and now it shows about 20 files for Carrara that failed to install. I've looked for what folder I should add to DIM to install but for the life of me can't remember where. I called up Carrara and looked also but just not finding it.
Can anyone help?
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,479
    Dim will not install Carrara files
    you can either unzip and manually install them or go to your content library and download installers for that content
  • 3DAGE3DAGE Posts: 3,311
    To Install Carrara files,. ... DiM needs to know where your Carrara "Application" is installed,..
    You can ADD the Application path to the "applications" tab, in the "Settings" in DIM.
    Once that's done,. DIM will install Carrara products and plug-ins into your Carrara folders
    Hope it helps :)
    Hi Wendy :)
    DIM was always intended to be able to install all store products, including app's, but at first it was only able to install DS "Content"
    now it can handle content for other applications such as Photoshop (Ron's brushes) or the Daz apps like Bryce Hex, and Carrara.
    most Content, still goes into DS or Poser,. but products built for Carrara should also be able to be installed using DIM
    It's moving forward, but some things still take longer than others.
  • whispers65whispers65 Posts: 952
    Hope it helps :)
    Thanks! I did see all of that last night. I just couldn't find the path that I was supposed to pick. This morning, I went through and searched for it and found it. Everything is installed now.
