I need to make my moon glow
DDCreateDDCreate Posts: 1,404
edited April 2018 in New Users
Apologies for the re-post. A while ago I asked in a thread how to make a moon. I got responses and I was able to do it. Recently I tried again and now I can't. I'm doing something wrong. I used a primitive sphere with a map of the moon. I render in Iray.
Pic 1: How it Looks
Pic 2: How it looks when I apply an emissive shader
Pic 3: How it looked when it worked last time.
Does anyone know what I'm doing wrong?
1537 x 923 - 184K
1547 x 925 - 210K
1034 x 610 - 102K
Post edited by DDCreate on
  • SimonJMSimonJM Posts: 5,999
    I am going to assuem Iray, so check the Emmisves settings - you may need to copy the diffuse map into the emmisive colour map and set the base colpur to white.
  • DDCreateDDCreate Posts: 1,404
    edited April 2018
    I did what you suggested and I noticed that applying the emissive cancelled out the map in diffuse. So I put it back in there and made sure that both emissive and diffuse had the map and were set at white. I don't see any marked difference between my first picture and this new one though :(
    EDIT: Well I guess there is a slight difference but not like the last one I put up. (not that it looks that great) But some "glow" would be nice.
    1348 x 653 - 142K
    Change the base colour of the emmisve map and turn up the strength of the emmisive?
  • BeeMKayBeeMKay Posts: 7,019
    The glow effect is from setting the bloom filter in render settings. You will have to experiment with the settings to get the desired effect.
