Look at my hair
Does Look at My hair ( https://www.daz3d.com/look-at-my-hair ) work (and work well) in Carrara 8.5 Pro?
Is it necessary to take full advantage of products like https://www.daz3d.com/cat-world-regenesis-hd-bundle
Thanks
  • StezzaStezza Posts: 8,165
    LAMH doesn't work in Carrara
    even if it is exported as an obj it won't load.... for some reason.. That's my experience with it.. I sent it back for a refund.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,371
    yeah you can export as obj in DAZ studio even with the free LAMH player but they are massive unrigged obj Carrara struggles with if it loads them at all, I prefer Carrara hair in Carrara as unlike LAMH it is dynamic and can be animated,  LAMH does not even sync for animation in DS with 3Delight unless you render one frame at a time and iray needs a fiberhair obj that is static too.
  • Thanks for the replies. I do most of my animation in Carrara, so having a product that only works in Studio isn't of much good to me.
    Any thoughts on https://www.daz3d.com/cat-world-regenesis-hd-bundle   -  I'm assuming that the main benefit of that over the earlier version would require LAMH and thus not be so useful if just animating in Carrara. Anyone know if that's the case?
  • Bunyip02Bunyip02 Posts: 8,734
    edited May 2018
    Skins on the Genesis Cat World figures are good in Carrara, I don't do animation so I don't know the pro's or con's.
    Edit : Tails will be an issue, as they are geografts.
    3157 x 1033 - 1M
    Post edited by Bunyip02 on
