Bblythe Hair for G8F - Causing Mark On Girl's Forehead
in New Users
I'm using Bblythe Hair and it is causing a mark on my character's forehead. I tried selecting the skull cap in the hair's Surface Tab and setting the opacity to zero, but that had no effect.
Any ideas what might be causing it? I tried the same character/pose/lighting with a different hair, and there's no mark on her forehead.
741 x 888 - 628K
The hair cap is intersecting with the head. Select the hair and check out if it has any fitting morphs in the Parameter tab. use either the ones for forehead, or in lacl therof, the expand all, and nudge it up one or two percent. Try again to render to see if the problem is still there.
Bee, that worked well, thank you so much.
