Can't attach a picture
wsgentrywsgentry Posts: 572
I've done it before--I had to resize the picture.  Now, even that doesn't work.  What's up?
Scott
  • BeeMKayBeeMKay Posts: 7,019
    edited May 2018
    Are you trying to upload an image, link to an image? What is your process? Do you get an error message?
    When you attach/upload an image, there's a size limit of how large it can be in MB.
    Post edited by BeeMKay on
  • FishtalesFishtales Posts: 6,161
    When you attach an image using the Attach a file at the bottom of the editor and then you choose file it looks like it is loading but then if the thumbnail doesn't show try posting your post. For the last few weeks this has been happening to me and when posted the attachment thumbnail shows up as the image has been uploaded after all.
  • wsgentrywsgentry Posts: 572
    Just doing it by clicking Attach a file, finding the file and uploading.  It shows uploading, then nothing.   I've resized and shrunk the picture down from 4.2 mb to 426k and the same thing.  :)
    Scott
    That's pretty much what is happening when I try to upload except I get no thumbnail, ever.
    Scott
    edited May 2018
    Scott
    What pixel length per side do you have, and what image format? Logging out, restarting the browser, and logging in again in the shop (not the forum) had no effect?
    Physical size is not too important.  KB size is   has to within 2mb to be accepted and in one of the accepted formats.  jpg, png and gif I believe.  I attach one of each to show,   THese are just selected at random from my HD.
    600 x 600 - 63K
    300 x 300 - 23K
    224 x 225 - 13K
  • pwiecekpwiecek Posts: 1,582
    Don't know if this is related, but the site used t not accept images if the file extension was in CAPS. This may or may not still be true.
    Just solved my problem. So it's obviously still the case.
    Thanks.
  • This is test because nothing has worked
    854 x 480 - 85K
  • This is happening to me also.  Image is 300K, all lowercase.  Testing it here now.
  • TaozTaoz Posts: 9,971
    Certain special characters in file name can prevent uploading, alphanumeric plus underscore and hyphen should be safe.
