How does this Skydome work?
DekeDeke Posts: 1,635
I bought the Orestes gloomy skydomes, but not sure how they work. I've installed and found a handful of items marked "render" but when I double click on one, it doesn't have any effects on the scene? Are these only visible in rendering?  Is there some other item I'm suppose to load and then apply these as materials?
  • BeeMKayBeeMKay Posts: 7,019
    • You can find new icons for loading this product in the following DAZ Studio Folders:
      • “Light Presets:Orestes Iray HDRI Skies”
    • You can find new icons for this product in the following DAZ Studio Categories:
      • “Render-Settings:Iray”
    You first select the Light Presets file. That will load the sky. The render settings than will adapt the rendering parameters.
    As this is Iray, and a HDRI Sky, you will only be able to see it when you render.
    You can try this product if it is a problem that you can't see the sky: https://www.daz3d.com/ibl-master-for-daz-studio
