How to transfer OBJ from Bryce.
Quietrob
How does one transfer an OBJ from Bryce for use in other programs?
Most programs can handle OBJ files with some tweaking. Bryce has some good models but transferring them has been tough.
Any idea's?
File > Export Object > choose Wavefront format
Thanks! I must be doing something wrong but I'll try it again and post my results.
Different things export with better or worse results, or potentially can't be exported in the way you might hope. There's a thread in the Bryce forum somewhere on this that I can't locate offhand. Is there a specific item you are trying to export? (terrain, tree, booleaned objects, some standard mesh object, etc.) That may affect the answer.
Make sure that the texture name doesn't have spaces in it, or it won't import correctly elsewhere. This might mean changing the default value.
You would probably get more answers in the Bryce forum, Would you like me to export your thread over there ?
