Current version of DS is 4.10.0.123, for both General Release and Beta. According to the release notes in the wiki, DAZ is currently working on version 4.11.
If you use DIM to install DS you should see new versions appear as an update to dowload when they are released. If you install DS manually (for the general release), check announcement threads in the forums to see when a new version is released, then download it from your product library.
Only the latest version can be downloaded at a given time, so keep backup copies of install files if you want to be able to rollback to an older version if needed.
That sounds good. Thank you for your a answer.
