File save always prompts for a new file name
phil_ffd678f3c1phil_ffd678f3c1 Posts: 12
Why do I always have to enter in the file name when saving a scene? This is a real nuisance.
Is there some new save setting that will simply do what save is supposed to do and no always act as a "save as" function?
  • frank0314frank0314 Posts: 14,056
    Annoys me to.
  • Richard HaseltineRichard Haseltine Posts: 100,948
    I have complained about this in bug reports - I really don't understand why it doesn't work like other applications. You can make a bug report, selecting Feature under Severity, to ask for them to change it - maybe they thought my plaintive cries were an individual eccentricity.
  • macleanmaclean Posts: 2,438
    Shouldn't it only prompt you on the first save? That what it does with me, and subsequent saves don't require confirmation.
    I don't see this behaviour as a bug. I'd hate to overwrite a scene through error because I wasn't asked.
    mac
    Other application ask for a name only on new, as yet untitled, documents - if you open a file (not merge/place it into an empty file) then you can save without needing to enter a name. I'm not convinced that prompting does protect from overwriting anyway - if one gets into the habit of clicking yes I do want to overwrite it because File>Save keeps acting like File>Save as then it will be very easy to say yes, overwrite when that isn't the desired behaviour. Like an over-active anti-virus, too many prompts can be as bad as too few.
  • NeilV_1NeilV_1 Posts: 442
    Personally I like this feature as if I open as Daz scene file if I add a light file from content or a complete scene file and I have not given my scene a name DAZ Studio will give it the name of that light set or or scene file so I see it as a safety back up device to make sure I don't overwrite my content.
    I don't fined it much hassle to click on that save button one more time I find it only happens the first time after I open a scene I have been working on and only on the first save of that session. after that I just click on Save and it saves or if I want to rename I have to click on save as.
  • SyndarylSyndaryl Posts: 521
    edited June 2012
    No version of Studio has ever behaved this way for me. It is very irritating.
    Then don't use Save, use Save As like you must be doing in other programs?
    Studio is currently the "odd man out" in behavior, for programs on all three major platforms (Mac, Windows, and Linux) for the behavior of an unqualified "Save" option in a File menu.
    I'd be a little more satisfied if they'd just rename it to "Save As" and label it correctly. That's what web-browsers do, since "Save to the current open file" is meaningless when you're talking about a webpage.
    What would be VERY useful would be versioned saving:
    IE, if I make a scene, and save it as "MyScene.duf", and hit the "incremental save" option, the current "MyScene.duf" would be renamed to "MyScene01.duf" and the current "MyScene.duf" would contain my updated scene. If I make more changes, and hit the incremental save button, I'd have "MyScene01.duf" and "MyScene02.duf", with the latest-greatest version still in "MyScene.duf".
    That way you have no way to have accidental overwrites, no annoying popup "What name do you want" windows where you can fatfinger your name or version number, you can go back a step (or two or ten) if you realize you liked what you did an hour ago better than what you're doing now, and you can show your process of assembling the scene to someone else if they challenge you on whether the render is really your own work or not. (The last one is usually more important when what you're doing is developing a commercial product of some kind than hobby rendering, but it's DAMNED important when it comes up)
    There's nothing like being able to show your entire process for proving you actually did the work. Like back in highschool on math exams.
    Post edited by Syndaryl on
  • ReDaveReDave Posts: 815
    It used to do as maclean says, for me too, but now on RC2 it asks for a filename each time. :-S
    Incremental save with duf scene files looks easy to script even to me. I may even give it a shot tomorrow.
    Well, and that was wrong by general practice too - if you Place something on the artboard in Illustrator or InDesign it doesn't replace "Untitled-1" with the name of the palced file, and DS shouldn't do that when Merging another scene into an untitled scene. I thought that one had been changed at some point in DS4, will have to check it hasn't reverted.
    Waarg, I didn't even really notice it was doing that! (Sorry NeilV, didn't quite get what you were saying there until I re-read the quote in Richard's post). My process though involves immediately saving with a filename to start the incremental filename thing so I guess I wouldn't run into it much. But that would be extremely frustrating!
    But definitely the solution to two bugs is not to keep one bug that happens to mitigate the other bug - the solution is to fix both bugs :)
  • SpitSpit Posts: 2,342
    Yeah, this bugs me too. And I think it was introduced in 4.5 because I don't remember it happening under 4.0. Could be wrong though. I didn't bug report it because my understanding was that for the RC's they only want major stuff reported (like crashes and inoperability of the new stuff).
    The change log is full of changes to save behavior so I suspect this may have been collateral damage.
  • 3d-username3d-username Posts: 0
    edited September 2012
    is this fix in the works?
    is there a script or another method to just save the file while working.
    the current method really makes saving a chore, so i save less, then when 4.5 crashes i lose more.
    in addition, export should populate with "filename" if the file has a name.
    any news? not to make waves but this is user interface 101
    Post edited by 3d-username on
  • BejaymacBejaymac Posts: 1,889
    Edit > Preferences > General tab and fill in your "authorship Information" (just the name part does), it's a "safety" feature to stop people overwriting someone else's files.
    thanks for the response, but that did not change anything.
    edit
    ahh it would seem i would have to re-save my saved file 1x to get it just to save. could the name metadata just be added with the computer name when the program is installed?
  • airjoeairjoe Posts: 13
    edited February 11
    This is still a missing feature, and that means we still have the downsides that comes with it.
    To be fair this feature could exist. I simply haven't found any switch to change that, so if it exists, thumbs up for keeping it hidden rather well :) .
    Using "Save As" as of version 4.22.0.15, and you'd like to give your scene a new version number for example, you still need to find the original filename and click on it.
    Or you look up at the top of your program window to know the exact title. That's not a priority to memorize to be honest, as I like to focus the least amount of what is considered technical management busywork. In other programs that I've used over the years, such as Photoshop, Affinity Designer, Xara, any office application, text editors, code editors, audio workstation software(Protools,Reaper,Cubase,Live,etc.) I rely upon the tool to fill in blanks so I don't have to.
    Currently I have to sort the file list in my "Save As" file requester by date. Or I type out the filename, hopefully without making a mistake if it's a more complex one.
    Shouldn't you guys at least give the user a choice ?
    It could be a little checkbox in the "Save As" dialog box itself. "Fill in current project file name" for example.
    Post edited by airjoe on
  • What OS are you using? For me, using WIndows 10, the standard oS fiel dialogue (which is what DS uses) offers a list of files that match the string so far typed - pick one, then edit. You could also write your own "Save Incremental" script, or just use https://www.daz3d.com/super-save
  • barbultbarbult Posts: 24,244
    Super Save is great.
