Genesis 2 Female not working in Carrara
PhilWPhilW Posts: 5,145
I thought I'd try Genesis 2 Female and Gia in Carrara 8.5. Not a happy experience - the Neomi character morph would not load (I needed to export from DS), the shaders required a LOT of work to look OK, and now I find that the Gen2 Fem clothes don't fit! How can clothes made for that figure not fit! I posted an image - the front view would not comply with ToS. I really hope this gets fixed in the release version of 8.5...
600 x 450 - 20K
  • kakmankakman Posts: 225
    There are a lot of problems using Genesis 2 with the Carrara 8.5 beta.
    The clothing problem stems from the fact that when clothing items are loaded the “Fit To” under the “Animation Group” in the “General Tab” is set to none. If you click on the drop down and select “Genesis 2 Female” the clothing will then fit to the figure.
  • PhilWPhilW Posts: 5,145
    edited July 2013
    I think I tried that and it didn't work. Well, it fitted it to the figure, but with more poke-through than visible clothing! As in the posted image. And that is the Basic Wear Top - designed for this figure!
    Post edited by PhilW on
    edited July 2013
    I do not have the Neomi character morph. But here is what I get:
    The first image is the Genesis 2 Female with the Basic Wear Top with “Fit To” set to the default “None”.
    The second image is the Genesis 2 Female with the Victoria 4 Body morph with the “Fit To” left set to the default “None”.
    The third image is with the “Fit To” set to Genesis 2 Female.
    Once the “Fit To” is set to Genesis 2 Female I can set various body morphs and the Basic Wear top does not exhibit the poke-through.
    640 x 480 - 49K
    640 x 480 - 51K
    640 x 480 - 51K
    Post edited by kakman on
    edited July 2013
    I get what you are saying, but it doesn't work for me on Neomi...
