Script/SDK to Perform a Button…
Daz 3D Forums > Software > Daz Studio Discussion > Daz SDK Developer Discussion>Script/SDK to Perform a Button…
Script/SDK to Perform a Button Action
DadofMany
I apologize if this has already been addressed.
Is there a way to call a pane button action via script/SDK?
Specifically I would press Render Pane, Advanced tab, Nvidia Iray Engine Bridge (Bets)] Tab, Add to Queue [...] Button via script/SDK.
I cannot find the action corresponding with this button. Should I try to capture an action or ID or is there an easier method?
Any assistance is greatly appreciated.
You can't directly access the renderer, since it's supplied to daz as a black box, just the settings (I assume you've seen Rob's sample scripts in that area http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start#rendering ). You may be able to access the pane controls via script, using code like https://www.daz3d.com/forums/discussion/comment/557942/#Comment_557942 to find out what is available.
Richard,
Thank you very much for the response and information.
Though I see there is a bit of work involved, you have given me a good starting point for my project.
I have made limited progress before getting stuck again....
Using the discovery script example I was able to find the setCurrentTab(int) function , I am able to select the Render Settings Pane and select the Advanced Tab with the code below. I'm trying to find a way to proceed from here.
var oPaneMgr = MainWindow.getPaneMgr();var oPane = oPaneMgr.findPane( "DzRenderSettingsPane" );if( oPane ){oPane.setCurrentTab(2);}
I have tried to "discover" the following functions but they don't appear to be the correct functions to allow me to proceed:
getContentTab()
getDefaultSkin()
getEditorGuidePage()
getElementEditor()
getOptionsMenu()
getOptionsMenuVersion()
getOverrideSkin()
getPaneGroup()
getPresetGuidePage()
From this point I would like to be able to select the Nvidia Iray Engine Bridge (Beta)] Tab, Add to Queue [...] Button via script/SDK.
