Help Using Transfer Utility
in New Users
Hi, I am having some issues moving from Marvelous Designer to Daz.
When I import my MD .obj into Daz, everything looks fine (image 2), but when I run the transfer utility I get a mess. Is there anything I am missing? Which settings should I look into changing in order to have a better result.
Thanks for any help!
511 x 585 - 114K
511 x 495 - 94K
For me it works best when I use a base figure (no morphs applied). Is that figure base G8F or base G3F?
I think you need to scale the imported obj mesh to be big enough not to touch any part of the DAZ 3D model you are using as the "from" model with the transfer utility.
It is Victoria 7. I will definitely try with the base figure now to see if it works. Thanks!
Will try this too, although I did some variation of it without luck :(
Yes, but you have to do all the scaling, etc before the import. Basically, load G3F base. Import your shirt and don't do *anything* else.
Inspect to ensure the shirt fits the base G3F with default pose perfectly.
If it doesn't, keep working on the shirt outside of daz (or inside if you want to export as an entirely new object) until you can import it so that it fits default pose great when all you do is import.
Once you hit that point, run transfer utility and it should be a lot smoother.
Thanks,I will try this
