How do you delete a part from the head?
Phantom StudiosPhantom Studios Posts: 203
edited December 1969 in Poser Discussion
Been trying to learn as I go and figure it out on my own but how do you delete a part from your character's head such as the nose? I checked it to unhide any morph targets but the dials don't really do anything to the nose.
I am using the Freak 4 Figure Base.
Thanks in advance!
Matt
  • Richard HaseltineRichard Haseltine Posts: 101,507
    Are you wanting to delete the mesh, leaving a hole, or to morph it flat?
  • Phantom StudiosPhantom Studios Posts: 203
    Morph it flat... I definitely do not want a hole. :)
    Any tips for that? Thanks
    Unfortunately if the existing morphs don't do what you want, and there aren't add-on morphs to help*, the only solution is to create one. You might be able to do it with one or a few magnets in Poser, and it is slightly easier in Poser than DS as you can use the Grouping Tool to restrict the magnets' area of effect, or in Poser 8+ you can use the Morphing Tool, but that kind of morph is quite tricky to do well, even resorting to an external modelling application.
    * which there may well be, if you scan through the DAZ store and the Freepozitory forum or beyond.
