Where are the rest of the V3 morphs?
To start off, no I don't want to hear about how I shouldn't be using V3 because she's old, I have my reasons why I'm using her.
Anywho, I was recently working on a project and I messed up some morphs when I did the full body morph, so I figured I would just re-inject them and fix the mistake, but then I realized that there are a bunch of morphs missing from the list after I removed them and adding them from the "all morph" for both body and head didn't replace them. I could get a much more detailed list, but the ones off the top of my head are the stretch arms/legs and a whole lot of head morphs like all four of the 'wince' morphs and 'mouth wide', just curious where I can pick up the rest of these morphs because they are not in the base figure installer or the head morphs installer
  • Richard HaseltineRichard Haseltine Posts: 100,833
    There were several morph expansions for V3, each of which came with its own figure file (this was why DAZ used te ExP system for the fourth generation figures, as it allowed new sets to be added to the base figure). Are you sure you were using a plain V3 and not one of the extra sets?
  • edited July 2013
    Not sure which version is plain, but I have http://www.daz3d.com/victoria-3-0-base and is labeled V3 SAE in Poser, which I believe was the latest version of her and this morph pack http://www.daz3d.com/victoria-3-0-head-morph-pack, besides third part morphs, what else would I be missing? I don't recall seeing anything else besides that set.
    Post edited by cujoe_da_man_c9406f7fe9 on
  • MattymanxMattymanx Posts: 6,904
    With the Gen3 characters you will find the morphs spread out across the figure. There are morphs listed at the base level and then there are more in teh head, hands and feet too I believe.
  • edited December 1969
    so, where do I get the files to re-inject those morphs into the figure? They're there when I load a new copy of her, but they aren't listed in any of the morph libraries
  • srieschsriesch Posts: 4,241
    I tried loading "Victoria 3 SAE", without injecting anything, selected her head, and in the Parameters pane under Morphs I see
    EyeWince1L
    EyeWince1R
    EyeWince2L
    EyeWince2R
    and if I select just "Victoria 3 SAE" in the Scene pane, then in the Parameters pane select General, I see
    StretchArms
    StretchLegs
    StretchNeck
    It may be that they are already there, I would check again. For some reason I always have trouble finding morphs and it usually takes me a few tries. I'll click on the head and it will select the figure but not the head so I don't see them, or I'll click on the head and it will select the eye and I think I selected the head, or I don't see the word "Morphs" sometimes the way I do other times and I assume they're not there, or whatever.
    edited July 2013
    http://www.daz3d.com/victoria-3-0-body-morph-pack
    http://www.daz3d.com/people/sci-fi-fantasy-morphs-for-vicky-3
    http://www.daz3d.com/people/victoria-3-character-morphs-add-on
    More here http://www.daz3d.com/people?compat_figures=46
    The body morph pack is cheaper when bought bundled with the head morph pack: http://www.daz3d.com/victoria-3-0-head-body-morphs and cheaper yet again if you buy the V3/M3 bundle instead http://www.daz3d.com/v3-m3-head-body-morphs
    Post edited by Lissa_xyz on
  • grylingrylin Posts: 278
    i still like v3 :D
    if you have the morph packs listed above for V3, look in the pose folder (I forget the original path) and you should find the inj's for the head and body morphs.
