Model Error
So the basic issue that I am having is, I made a model with V4 and applied Zbrush morphs to her using the GOZ plug-in with DAZ. The issue is that I saved her model, then a short while after DAZ decided to crash on me. I tried to reload her scene and got no error, but the problem is that her model did not come out how I saved it... She loaded as A box model. I really do not want to make her morphs again because I spent like half the day making her morphs.
Help would be greatly appreciated.
395 x 608 - 50K
Check to see if the crash caused your Viewport to swap to Bounding Box View, that is in the Sphere Drop down menu at the upper part of your Viewport.
I have already tried that. I might have to redo her morph. I have no clue how it happened, I've never experienced that before on any of my models so I have no idea why she decided to do so. When ever I try to render her only the clothes show up. So I think her model is done for.
Sorry, I'm no help I only do minor morphs in Hex.
Well thanks for your reply hopefully I can get her to work for me if not, then I guess I will have to redo her. No use in crying over spilt milk...
If you saved her morph, then you can simply reload it. It's often recommended to save morphs so that you can reapply them later, should you need to. That said, this sort of error looks as though it's having more difficulty finding V4 rather than the morph. Even if a morph fails, it will still load the figure in.
Double check that V4 works on her own, and assuming she does, that she hasn't moved to a different content folder since you used her last.
She doesn't even show up in the material editor in DAZ when I select her. So I assume that her model just disappeared on me. I only saved her as a scene. I didn't think to save her as a morph file because I never had that issue before. I have remade her morphs so I think i'll do fine for now. Thanks for replying
