How to use a DSF shaping file?
Sylva1nSylva1n Posts: 0
Hello,
using the bridge between DAZStudio and Hexagon, I've managed to create the morph I needed.
It appears in Parameters>Morphs>Hexagon.
Then I saved it using the Save As DSF shaping file, but I don't understand how to use it when I'll need it in another scene.
Could you help me?
best regards,
Sylvain
    Once saved as a DSF morph it should load automatically with a fresh Genesis. It won't be applied to figures you have saved as .daz scene files, though those in .duf files (DAZ Studio 4.5) should update to use the new morphs.
  • Sylva1nSylva1n Posts: 0
    In which panel should the new saved morph appear with the fresh Genesis?
    thanks
    It should appear wherever it appeared after initial loading - its location is one of the things that gets saved. If you are using DS4.5 and didn't assign a region to the morph it won't show in the Shaping pane.
  • DarkRepastDarkRepast Posts: 223
    Thank you all. I figured it all out. The links above assisted. It's both simple, and not at the same time. But I got what I needed out of it so thanks!!
